Posted by: Matt
Date: 09-01-2012 03:38:42
Just make up a soapy water solution and spray it on any suspect bushes or parts one by one and check if the squeak disappears after spraying each possible suspect. The mix should give enough lube to check each part out without contaminating owt.
